Radiator overflow plastic nipple
Old May 29, 2013 | 08:45 PM
Colorado David's Avatar
Default Radiator overflow plastic nipple
I don't want to change my radiator because the overflow plastic nipple broke. Does anyone have a good permanent fix? I thought about drilling it out enough to fit a small piece of copper tube down the middle of the nipple and cement it all together. What type of glue works best on this type of plastic? Thanks.
Old May 29, 2013 | 08:49 PM
None is releiable forever. The tank plastic gets brittle. Some have drilled out, threaded, and glued in a threaded nylon hose b*a*r*b. JB Weld. You may prefer to have a $150 ish replacment radiator than a patched one that may crack elsewhere.
Old May 30, 2013 | 12:06 AM
This is the one I think I'll get if I have to. Land Range Rover Discovery OEM Radiator
It's not $150.
Old May 30, 2013 | 12:16 AM
Others have posted about radiators at about half that. Of course, quality is always an issue. Here's pix of what is inside that plastic tank, not a lot of meat to work with.
I think the low price ones were http://www.carparts.com/details/Land...FU1p7Aoddx0AJg
Attached Thumbnails Radiator overflow plastic nipple-d2-rad-top-scew-crack.jpg
Old May 30, 2013 | 07:55 AM
Dave, you get what you pay for in this world, I recently installed that same radiator in my Disco, yes, it is more expensive and the only one that is not a American made knock off or worse yet from China. It is stamped right on the box, it is made in Scotland.
Don't forget to replace your t/stat with a new 180 degree soft spring if you have not already done so.
Old Sep 14, 2019 | 12:06 PM
Darwin's Avatar
Forgive my responding to a very old post, but this just happened to me, while trying to fix a squeaky fan belt on my 2000 DII. The thought occurred to me that if the radiator is now trash, what do I have to lose trying to fix it. There are any number of hacks that will solve this problem. Here is the hack that worked for me:
I took a 1/4" carriage bolt out of the junk draw and center drilled a 3/32 hole, 1.5" through the middle if it. I used a small lathe, but you could use a drill press or even a hand drill, if you first make a suitable center guide. I then trimmed back the broken plastic stub sticking out of the radiator, using a razor knife, and drilled a 7/32 hole through the middle of it. (I spun the drill bit by hand, to avoid launching it through the front of the radiator if it bit the plastic too hard...)
The 1/4" bolt threaded quite nicely into the new 7/32 hole in the radiator. I removed the bolt, cut it off at 1.5" and re-threaded it back into the radiator. The hose fit loosely over the threads and was secured with a clamp. DONE!
At some point, I'll probably need to replace the radiator, but it won't be today, and it won't be because of this ridiculously flimsy plastic connector.
Old Nov 1, 2025 | 10:10 PM
ArdP's Avatar
Hi Darwin,
that’s an awesome solution, just carried out your procedure and all good!
Thankyou
FlyingZebra34
Sep 15, 2014 11:30 PM
steveo2000
Sep 1, 2011 03:14 PM
bcolins
Jun 2, 2011 07:40 PM
Rangie_
Aug 7, 2009 08:03 AM
DavidG
Jul 11, 2009 09:38 PM
