Radiator replacement and aftermarket parts
No problem but thanks! I'm going to pull the trigger on everything. Rad, water pump, thermostat, belt. It stinks, as all that stuff isn't very old. Oh well, better safe than sorry.
I have reused the same serp a few times, it was put on new when we bought it last year and doesnt display any wear...if yours is good, I would keep it for a spare...
As far as the water pump, I just see if the pump wiggles at all, if it doesnt then I will reuse it. I just redid the timing chain, sprockets and the gaskets that are in the front, etc...I reused the water pump. It looked really clean inside and the bearings seemed to be super, as I had no wiggle.
The Rad is obvious and the stat shouldnt hurt.
disco bcameron70
Audio/Visual Electronics
12-02-2010 05:57 AM
