Radiator temperature difference...
Old 04-11-2014 | 03:00 PM
grandkodiak's Avatar
how many hours is that electric pump rated for?
Old 04-11-2014 | 03:11 PM
dusty1's Avatar
3000 continuous
7000 with its controller
that is if used as primary pump. I still have it set up as secondary booster. once I reach the set temp (185), it doesn't come on, unless I get to 190 and off at 181. so, only sees off road use, but it will prolly come on when the 100+ temps get here......right around the corner.
also I have it run through a switch, so I can disable it for part of the year, when heat soak is not an issue.
Externet
11-26-2012 10:19 AM
F451_Guy
12-11-2006 08:54 PM
IH1973
08-04-2006 12:00 PM
rirover
07-07-2006 08:22 PM
roverATH45
06-05-2006 10:56 AM
