Radiator temperature difference...
Old Apr 11, 2014 | 02:00 PM
grandkodiak's Avatar
how many hours is that electric pump rated for?
Old Apr 11, 2014 | 02:11 PM
dusty1's Avatar
3000 continuous
7000 with its controller
that is if used as primary pump. I still have it set up as secondary booster. once I reach the set temp (185), it doesn't come on, unless I get to 190 and off at 181. so, only sees off road use, but it will prolly come on when the 100+ temps get here......right around the corner.
also I have it run through a switch, so I can disable it for part of the year, when heat soak is not an issue.
Externet
Nov 26, 2012 09:19 AM
F451_Guy
Dec 11, 2006 07:54 PM
IH1973
Aug 4, 2006 11:00 AM
rirover
Jul 7, 2006 07:22 PM
roverATH45
Jun 5, 2006 09:56 AM
