Radio cut out problem
Old Apr 22, 2012 | 11:15 PM
BradSwanson's Avatar
Default Radio cut out problem
Hi All,
I seem to have a short in my radio as it cuts out for a split second while driving. I have not noticed any pattern to it as it can even happen while sitting at a light. Electrical stuff scares the electrons out of me, any advice on where to start?
Old Apr 23, 2012 | 03:07 AM
Discovery SE7's Avatar
Find the security code for the radio before anything. Even if you take it to a car radio shop, it could lock itself if the radio is removed in order to investigate a short.
Old Apr 23, 2012 | 04:16 AM
x2 on the security code.
Here's wiring and fuses for the base radio, on the high line radio it is similar (more in the RAVE). Could be a cracked or loose fuse, but note that fuse 20 feeds radio memory. The high line radio with separate power amp has a different layout, even includes a feed from the SLABS (fun fact) for road speed. Perhaps that allows the sound level to auto adjust for road noise. Or just charge up the flux capacitor, so when you enter the right sequence on the radio you are transported back to when Motown ruled the earth.....
File Type: pdf
pgaukroger
Feb 29, 2016 05:56 AM
brian4d
Mar 16, 2009 09:56 PM
mooal5
Dec 18, 2007 11:34 AM
mbrummal
Feb 25, 2007 03:07 AM
