random clunk!!
Old May 27, 2010 | 08:33 PM
03discoman's Avatar
Default random clunk!!
i was test driving my disco after changing out a bad coolant hose and i felt a clunk when i pulled into my drive way... i was in high range with the diff unlocked... driveshafts are good and i never felt this before i did the CDl install..
do you guys get random clunks in the drivetrain?
Old May 27, 2010 | 08:43 PM
Laugh out mother trucking loud so hard that I pissed my PJ's and I need to take another shower.
Old May 27, 2010 | 09:00 PM
Ok, ok, I've changed and now I can give you a better answer.
You have added more moving parts to your driveline, its going to make noise.
Make sure all four tires are at the same PSI, double check as much of your work as you can and I wouldnt really worry about it.
Mine makes random clunks too, but I expect that with almost 200k on the clock.
And for what its worth, mine has made the same clunk since I bought it with 152k on the OD.
Old May 27, 2010 | 10:00 PM
JavaDiscoII's Avatar
Is having all four the same psi better than the 30F 38R (I think)
Old May 27, 2010 | 10:53 PM
Camdisco24's Avatar
I think you're paranoid.
You worked so hard on that truck, your now looking too hard for issues!
Old May 28, 2010 | 08:17 AM
^^ I definitely know that feeling. I have a new prop shaft that is 6k miles old (prev owner, not greasable, oh well I will worry about it in 10k more miles). Anyways, I was driving with the windows down and started hearing a clicking noise and began having a panic attack. Picked up my phone to call the service centre, then decided to use some common sense. Pulled over, I had a huge stone in my treds.
Old May 28, 2010 | 06:04 PM
I have found that running all four tires at the same psi reduces the clunk.
I can tell when one tire is low by the sound of my clunk.
DiscoMike2003
Nov 13, 2008 04:57 PM
Airwolf1
Nov 11, 2006 10:36 PM
msbont
Sep 10, 2006 03:53 PM
bmartin2
Feb 18, 2006 02:49 AM
Sarge
Jun 4, 2005 07:57 PM
