Random valve 3 amigos year or so after option b
Old Jul 1, 2022 | 07:53 AM
Sandman614's Avatar
Originally Posted by mln01
The ground we are talking about here will not be found in RAVE. It's the ground point created when Option B is done.
Josh Salas chose to use the refrigerant line clamp bolt next to the ABS module as the Option B ground. That's what I did (pictured here).
Right I understand that, I meant the original ground for the ABS modulator, C0561-1. I want to check the original ground before doing option-b
Old Jul 1, 2022 | 03:44 PM
mln01's Avatar
Here you go. Based on this illustration from the RAVE Electrical Library, C0561 is behind the airbox on the front bulkhead (or whatever it's called). I looked and there are grounds there on my truck.
Old Jul 2, 2022 | 04:46 PM
Sandman614's Avatar
Ah that makes sense I see them now, if they would have zoomed out just a hair more I would have realized that's the ace/steering reservoir.
austinlandroverbill
May 17, 2017 06:40 PM
NiteTrain
Nov 23, 2013 08:00 PM
GadgetRick
Feb 9, 2012 10:18 PM
joatman
Jan 11, 2011 08:39 AM
