rapid left turn signal?
Old Dec 6, 2017 | 03:11 PM
09dewaed's Avatar
Default rapid left turn signal?
My left blinker is 2-3x faster than the right. I know this to be indicative of having a light out. All three turn signal lights work on both sides of the vehicle. The headlight blinker assembly looks mint. The tail light assembly had water in it. I cleaned and dried it out and cleaned up the terminals on the bulb (which weren't necessarily bad to begin with). How can I troubleshoot the problem from here? thanks!
Old Dec 6, 2017 | 03:55 PM
abran's Avatar
did someone sneak an LED in there?
Old Dec 6, 2017 | 03:56 PM
LR03NJ's Avatar
Bulb busted or grounded circuit. Did you change to led?
Old Dec 6, 2017 | 04:16 PM
OverRover's Avatar
Remove and check the R1 Relay in the Passenger Fuse Box.
> Relay (YWB10004L Same Fit As Part # YWB10004L ) - Land Rover connector\relays\flasher from Atlantic British
Old Dec 6, 2017 | 05:15 PM
09dewaed's Avatar
No LED, unless under the side marker turn signal. Thanks for the info on the relay I’ll check that asap
Old Dec 6, 2017 | 05:22 PM
OverRover's Avatar
Knowing that the RH side indicators are working you can also try switching the R2 relay with the R1.
Old Dec 6, 2017 | 05:32 PM
09dewaed's Avatar
I swapped the two relays and the problem persists on the left side. The first few clicks of the left signal are (sometimes) the correct rate and then it speeds up.
If I unplug the entire light assemblies (headlight, then Side marker, then tail light) will the problem correct itself once I unplug the problematic unit? Or will unplugging a working unit cause the light to speed up. just trying to think of a diagnostic method.
Old Dec 6, 2017 | 05:38 PM
09dewaed's Avatar
I was playing with the passenger side signals (they work fine) and if you unplug any of the signals, that entire circuit blinks rapidly.
Im thinking ill have to replace every bulb on the left side of the vehicle in order to rule out the bulbs.
Old Dec 6, 2017 | 06:23 PM
09dewaed's Avatar
where can I find the grounds for the turn signals?
Old Dec 6, 2017 | 08:02 PM
09dewaed's Avatar
I replaced each bulb from front to back. One by one I check the turn signal function. The rear signal on the drivers side had, what I believe to be, the incorrect bulb in it. Check the photo. New light has one terminal Turn signals are functioning correctly. For now..
