rapid left turn signal?
Old Dec 6, 2017 | 09:47 PM
That'll do it
Old Dec 6, 2017 | 10:39 PM
OverRover's Avatar
GIVE THAT MAN A PRIZE!!!! You definitely found your problem, that poor bulb/BCU did know what the hell was going on.
As you have figured out the correct bulb is a S8 Single Contact Bayonet #7506 from any auto parts store.
To confirm it for you > Turn Signal Bulb - Front Or Back
Also check the sockets(bulb holders) & connectors for corrosion and use a little dielectric grease on the contacts.
Old Dec 11, 2017 | 02:52 PM
Nickfletcher's Avatar
Originally Posted by 09dewaed
My left blinker is 2-3x faster than the right. I know this to be indicative of having a light out. All three turn signal lights work on both sides of the vehicle. The headlight blinker assembly looks mint. The tail light assembly had water in it. I cleaned and dried it out and cleaned up the terminals on the bulb (which weren't necessarily bad to begin with). How can I troubleshoot the problem from here? thanks!
this happens on every car, it’s when the bulb is about to go out, happened with my passenger blinker, changed the bulb and fixed the problem. Haven’t had it happen in over a year
Thatdudeuno1
Mar 11, 2012 11:13 AM
rankar
Jan 2, 2010 09:40 PM
satcal0
May 3, 2009 01:54 PM
Gomie
Feb 3, 2009 03:16 PM
LordOphidian
May 30, 2006 03:00 PM
