Rear alignment...
Is correct to say the Discovery II (with air suspension) have an "individual alignment" ...? or for this rear suspension type, the toe will´be set on each rear wheel individually?
The (oldest) right rear tire have excess of toe-out and the shoulder was very damaged.
Thanks.
Edit: the tire damaged was on the rear right side...
Thanks.
no adjustment on discovery due to like he said solid axel. LR3s have control arms and do have rear toe adjustment. the only adjustment in the rear for a discovery is the air suspensrion adjustment where you fit two blocks and use t4 to calibrate/adjust ride height. if you have wear in the rear maybe you have bent suspension components or worn bushings.
A few months ago, a friend made a calibration with Rovacom and yes, the vehicle was an incorrect rear hights (more hight at left side, maybe 3-4 cms.)... and now reading your information I think it was the cause for that tire damage, the tire on the opposite.
Now, the rear hights are correct.
Thanks...
Thanks...
CANAMDiscovery
Jul 16, 2010 06:19 AM
Waggy23
May 16, 2007 10:00 PM
jomeheretu11
Oct 31, 2005 06:55 AM
