rear axel seal
Old Jul 9, 2013 | 05:26 PM
cbrantner's Avatar
Default rear axel seal
My 04 Discovery is with a non-Land Rover mechanic who said that he can not find a rear seal and bearing.
Within minutes, I ordered 2 O-ring seals from Atlantic British and the sales tech said that I probably do not need a bearing because I do not hear a grinding sound.
The mechanic also said that I might need a new rear axel if the bearing is really bad.
If anyone has any knowledgeable thoughts on this, I would greatly appreciate it. I plan to ship the truck to Sweden on the 18th and any leaks will be a big problem and expense there.
Thanks in advance!
Old Jul 9, 2013 | 05:34 PM
jafir's Avatar
The axle shaft doesn't ride on roller bearings like some cars so it is unlikely that a bad bearing would cause the shaft to wear out.
Old Jul 9, 2013 | 09:13 PM
Why are you wasting your time and money on someone who does not now squat about your truck???????
You either have a bad o-ring between the hub and axle housing or a failing hub.
Old Jul 10, 2013 | 09:28 AM
cbrantner's Avatar
Thanks for the advice!
What does the axel ride on if it is not roller bearings?
I thought I only needed new front brakes and a battery cable. The nearest mechanic is over an hour away and the truck is not registered or insured, so I had it towed to a closer place.
Is there any reason I should not trust this guy to do the job? He works mostly on fords and my Mother's Smart Car.
Old Jul 10, 2013 | 10:30 AM
jafir's Avatar
I guess you'd call it a race that is part of the sealed bearing assembly. The axle is pressed (or at least a tight fit) into the center of the seal unit. This race is what rides on the bearings.
I think I remember the axle shaft of an old Heep Cherokee I had that the axleshaft itself was the bearing race, and after enough time you had to replace the bearing and the shaft.
Old Jul 10, 2013 | 03:59 PM
Why use someone who is not familiar with your Disco, he has already proven this by his suggestion to you.
So as I stated before it can be either a $2 o-ring or a $400 plus labor hub, are you willing to let this guy get you?
bluelinerover
Aug 8, 2024 09:16 AM
twr7cx
Aug 27, 2023 03:44 PM
clint70
Jul 11, 2015 03:14 PM
TRIARII
Oct 4, 2014 09:19 PM
bluelinerover
Feb 20, 2014 10:00 PM
