Rear Brake Piston Won't Retract
Old Nov 28, 2014 | 11:41 AM
DSCVRY's Avatar
Default Rear Brake Piston Won't Retract
I set out on a quick brake pad change two hours ago and here I am. I cannot get the driver's side rear brake piston to retract for the life of me. I broke two c-clamps trying and even rented the piston tool from Advance Auto. Any tips?
Old Nov 28, 2014 | 12:01 PM
drowssap's Avatar
That meens the caliper is frozen and needs to be replaced
Old Nov 28, 2014 | 12:02 PM
DSCVRY's Avatar
Nothing else to try?
Old Nov 28, 2014 | 12:14 PM
drowssap's Avatar
Nope it should retracted fiarly easily, you could try cracking thr bleeder screw. But if it requires that much pressure to retract it will freeze up again. Jmho
Old Nov 28, 2014 | 01:01 PM
The_OGCJR's Avatar
drowssap is correct.
Old Nov 28, 2014 | 01:25 PM
DSCVRY's Avatar
Well, ****ty news, but I appreciate the news nonetheless. Thanks.
Old Nov 29, 2014 | 04:44 PM
OffroadFrance's Avatar
Sadly, drowssap is right. It's rust or corrosion which usually seizes the piston into the caliper bore and even taking it apart and polishing the piston and bore will probably work OK for awhile but once the coating is worn off the corrosion will set back in. Problem is the rear calipers don't work anything like as hard as the fronts so they don't get the 'exercise' needed.
Old Nov 29, 2014 | 10:44 PM
T.J.'s Avatar
Rockauto has good prices on rebuilt calipers.
Old Nov 30, 2014 | 11:38 AM
Thumbs up
"I couldn't fix your brakes, so I made your horn louder".
Magic Like
Disco_Fever
Feb 16, 2023 03:18 AM
airmarc
Jan 11, 2012 12:01 PM
LRScott
Apr 9, 2009 01:44 AM
smllikphysh
Oct 27, 2008 06:44 PM
sanchez
Aug 3, 2006 10:24 PM
