Rear cargo speakers
Old Sep 18, 2020 | 11:28 PM
Silverredx7's Avatar
Default Rear cargo speakers
Is there any speakers that’s close to a direct for the rear cargo subwoofers .My subwoofer are shot previous owner had leaks from the tailgate. Was thinking of replacing them with 6.5 waterproof speakers just in case but can’t find a compatible pair
The Bus
Old Sep 19, 2020 | 08:53 AM
Best4x4's Avatar
Pyle Subs
Old Sep 20, 2020 | 07:13 PM
Default Pyle
Ordered the Pyle fit was perfect. But could not get them to work just a humming sound
the radio is a aftermarket so it may be that or they did not connect the amp the correct
way and my other speakers are fine if you crank up the music but I get a hissing sound
from them
Old Sep 21, 2020 | 08:12 AM
JUKE179r's Avatar
They are wired wrong then. I have those Pyles also and they work fine for me and I don't have the Hi-fidelity system.
Old Sep 21, 2020 | 11:02 AM
Ok so most likely wired wrong from the radio or wires that connect to the subwoofer speakers
The plye are labeled positive and negative so it could be from the radio.
Old Sep 21, 2020 | 12:16 PM
Dave03S's Avatar
If you had the positive and negative backward and that was the only problem you would still get sound. Problem is more likely signal level from head unit to sub amp.
Old Sep 21, 2020 | 12:44 PM
Thanks just trying to get some bass lol
Thanks Dave I will most likely take it to a stero location I’m sure it’s the radio
trying to avoid wires being cut and have different ppl dealing with the radio issues
THE BUS
nashvegas
Aug 6, 2022 03:07 PM
Big Jim Swade
Jun 1, 2021 01:15 PM
aftermath431
Audio/Visual Electronics
Sep 10, 2014 09:36 PM
leddifer
May 4, 2010 09:02 PM
discoguy
Jun 22, 2008 07:15 PM
