Rear Diff weight mount - help needed
Old May 14, 2017 | 06:54 PM
Rover_Hokie's Avatar
Default Rear Diff weight mount - help needed & bolt size
On the trail a few weeks ago had a "friend" blow my rear diff. He replaced it personally. He told me my QT diff guard that wraps over and under the diff had taken a beating over many trail rides and was cracked about to come apart. I have another diff guard I finally ordered last week on its way in the mail.
Fast-forward to yesterday a block from home I hit a pot hole and heard a noise and then scraping all the way home. Looked under and my diff guard is gone and my rear diff weight mounting plate is dragging the road held on by the cable. I haven't gotten under for a more detailed look yet, but hoping someone can give my a pic of the weight mounted as I do not recall the mounting exactly and bolt size needed as I assume they are gone as well.
Old May 14, 2017 | 07:05 PM
OverRover's Avatar
Have at it > www.discovery2.co.uk / Rear diff guard / Rock Slider
Old May 14, 2017 | 07:52 PM
Well, that would explain why the diff guard and weight are both not attached. It has been a few years since I installed the rear diff guard, but I do recall the mounting now as the weight ended up on my chest Thanks!
Can anybody give me the bolt size needed to reattach the weight?
Old May 14, 2017 | 09:23 PM
OverRover's Avatar
The thread size/pitch is M10 X 1.25 but I don't know the length. Should be easy enough to determine with a depth gauge. But if I had to take a GUESS... about 30 to 35mm with a washer, or 25mm if it's a flanged bolt. Whatever you do get Grade 10 bolts!
Good Luck.
Old May 14, 2017 | 09:53 PM
tcr6v1's Avatar
This reminds be... I should probably get the safety cable for my weight fixed, completely rotted out.
Anyways if you still need the length by tomorrow I can pull mine out and check for you.
Old May 15, 2017 | 06:10 AM
BackInA88's Avatar
That weight has been off my rig for over 10 years with no ill effect.
Old May 15, 2017 | 08:09 AM
JUKE179r's Avatar
I was thinking of removing mine also.
Old May 15, 2017 | 04:51 PM
acg's Avatar
acg
What is the purpose of this weight?
Old May 15, 2017 | 04:59 PM
OverRover's Avatar
Vibration damper.
Old May 15, 2017 | 05:35 PM
Thanks for all the help.
The tapped hole in the housing is about 21mm deep, and the heavy L mounting bracket is about 6mm thick, so about 27mm total and then the extra layer of the skid plate mounted on the flange for the bottom mount that is maybe 2-3 mm thick of the wrap-around style diff guard. I think I will go with 25 mm flange bolt. I think I will try some lightweight loc-tite and/or a star-type lock washer this time around
Rover_Hokie
May 14, 2017 06:42 PM
jamieb
Mar 27, 2016 01:06 PM
khuds308
May 13, 2013 09:48 PM
JamesDisco97
Mar 4, 2012 01:21 PM
weatherman
May 3, 2007 05:12 PM
