Rear Differential Question
Old May 22, 2014 | 05:47 PM
dusty1's Avatar
so, you don't need this free diff........i'll scrap it.
Old May 22, 2014 | 05:51 PM
ralphobell's Avatar
No hold on to it. I still want it!
Attached is the picture of the carnage!
Old May 22, 2014 | 05:58 PM
ralphobell's Avatar
You don't need that tool. I drove my rear end up on ramps and chocked the front tires. The diff will not move. You only need that tool if you put it on jack stands or a lift.
The bolts for the rear shaft are 3/8 UNF I think 1 1/8" long. Microcat doesn't specify length.
EDIT: Previous wrong part number!
Land Rover Part # FRC3602 (superseded
Superseded by LR045926) 3/8 UNF X 1 3/4, Flange to Propshaft
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
Originally Posted by Jared9220
Very nice Ralph, thanks.
I have been scared of doing the seal in the diff because of the flange nut and all the horror stories. I'm not sure your experience has built up my confidence any.
I think i'll use this repair as an excuse to buy a new tool. I found this Universal Pulley and Flange holding tool for $78 and it seems like it will be money well spent for this job.
OTC 4754 Universal Pulley and Flange Holding Tool | Engine, Trans., and Driveline Tools
Do you by chance know the replacement bolt size you used so I can pick up extra hardware before tearing it apart?
Old May 22, 2014 | 06:11 PM
fishEH's Avatar
Originally Posted by jafir
Ashcroft suggests drilling and tapping the hole to 12mm.
DiscoWeb Message Boards - View Single Post - Rotoflex conversion nightmare
Do this and make a puller. I used some reducers and other junk from the local Home Depot. Use a few high quality bolts and change them out, don't want to shear one off. Use a lit of heat. You'll get it out.
Old May 22, 2014 | 06:13 PM
Jared9220's Avatar
Thanks Ralph. I'll save my dough for something else.
Old May 23, 2014 | 08:12 AM
ralphobell's Avatar
Jared,
Provided the wrong info in earlier post, it has been edited to below:
Old May 23, 2014 | 10:24 AM
jafir's Avatar
I don't own any of them girly cars with rotoflex....
Mies
Oct 7, 2014 12:13 PM
Classic89
Aug 23, 2007 04:06 AM
Classic89
Aug 22, 2007 07:26 PM
Classic89
Aug 22, 2007 05:17 PM
Classic89
Aug 21, 2007 07:52 PM
