Rear Door Actuator or not?
Old Sep 28, 2011 | 08:27 PM
marshman442's Avatar
Default Rear Door Actuator or not?
I have read through the forum and don't see different symptoms for a bad actuator vs one that just needs to be cleaned.
My rear door will lock but not unlock. It has been like this for a few years now - and jumping the seat is getting old.
About a week ago I had the symptoms of the lever getting stuck, so I popped the emblem and cleaned and lubricated. - Problem solved.
So before I spend a bunch of money replacing the actuator, does anyone know if it were shot why would it still lock the door? Or is this the symptoms of an actuator that just needs to be cleaned?
Old Sep 29, 2011 | 06:35 AM
rreinholt's Avatar
My 2004 did the same thing. I took the door panel off to see what was going on, unpluged the actuator, plugged it back in and now nothing. No power back there at all. Looking for input as well.
Old Oct 7, 2011 | 10:15 PM
no takers on this one hugh?
Old Oct 8, 2011 | 01:55 AM
Adigorn's Avatar
if it locks and do not unlock the only permanent solution is replace whole latch
the selenoid is part of the latch all the WD40 solutions wont work or last long
kristofferzen
Sep 10, 2015 02:11 PM
canbuster
Nov 9, 2009 06:54 PM
