rear door adjustment? Sagging? Dragging?
BINGO! I have the same issue and we determined that the hinges are bent. Most likely the previous owner opened the door on an incline and the door flew open and bent the hinges. That's a heavy door with the spare attached to it. Yes, you can try adjusting the hinges or even shimming them but my plan is to replace them. Seems like a fairly common problem if you search the forums.
Can the hinges be loosened and door adjusted? Apreciate any guidance / help.
Cheers!!
So how did you adjust the other doors? I tried the directions in RAVE but didn't allow enough play to adjust the rear of the door upwards enough to make a difference.
