Rear Fogs won't turn off.
Old Jan 29, 2016 | 03:47 PM
SinisterMoose's Avatar
Default Rear Fogs won't turn off.
1999 Discovery Series II
The amber "active" light is lit on the rear fog light switch, and the rear fogs are lit, and no amount of pressing the switch will turn them off. I should preface this by saying that they are only active when the parking/headlights are on, and they shut off when I turn the parking/headlights off.
I've even taken the binnacle off and made sure the connections are good, as well as replaced the binnacle and switches with one pulled from a salvage yard.
I'm hoping this doesn't point to a BCU problem, and instead points to a relay stuck closed.
Old Jan 29, 2016 | 04:32 PM
jfall's Avatar
Sticking relay.
Replace it.
To turn them off for now - pull the fuse.
Old Jan 29, 2016 | 04:34 PM
jfall's Avatar
Sounds like a short.
Make sure no Bozo the Clown installed an aftermarket ANYTHING in your rover
and screwed up the wiring from OEM.
That is probably the problem.
Old Feb 1, 2016 | 05:19 AM
Originally Posted by jfall
Sticking relay.
Replace it.
I snagged a handful of relays while at the junkyard this weekend from an '03 Disco, so I'll try this to see if I can get a response.
Old Feb 1, 2016 | 05:26 AM
The truck is unmolested, and fairly entry level. The only modifications that have been done, I've done and that was only the radio. There is a dealer installed receiver hitch, and the trailer wiring is Land Rover branded.
I'm curious if maybe the bulbs that have been installed are the wrong wattage/amperage for the rear fogs and maybe that has cooked the relay.
I've replaced a couple of the brake light and other bulbs and they've all been "odd", not the typical 1156/1157 in most older American vehicles.
I'm just going to order all the correct bulbs for the back of the truck and replace the relay. Maybe that'll cure it.
Old Feb 1, 2016 | 01:50 PM
number9's Avatar
If other recommendation fail to fix it. Switch may be bad. It's a non-latching type. Contacts may be stuck together which would turn them on with other lights. Switch can feel good and still be sick.
Old Feb 1, 2016 | 09:34 PM
Best4x4's Avatar
I am using the Sylvania Zevo 1156/1156R LED's in my D2. The proper incandescent bulb is a P21 5watt, but the Zevo 1156R is 1watt so it'll work fine. 1156 in the rear fogs = to many watt's and it'll melt your lens/housing eventually. Sounds like a stuck relay to me.
Brumski07
May 1, 2009 08:17 PM
cgpilot1id
Apr 22, 2009 11:59 AM
KBW
Mar 24, 2009 06:28 PM
Dublz
Sep 14, 2007 12:36 PM
