rear hub options
Old May 7, 2017 | 07:04 PM
OffroadFrance's Avatar
Buy an aftermarket as with LR OEM you're paying double/treble for the name. Britpart had a bad reputation at one time but are good now so go with a Britpart unit. The front and rear bearings are interchangeable and are the same.
Don't forget to replace the hub staked nuts with new ones, also Britpart. Also advisable to replace the rear O rings and clean up the mating locations.
TIP: Timken are a top class bearing manufacturer although most bearings are made in the EU or far east now.
Old May 7, 2017 | 07:12 PM
usaf_disco's Avatar
thanks everyone for the opinions. Ill snag one and if I have issues report back with mileage and time on the unit etc.
Old May 7, 2017 | 07:24 PM
usaf_disco's Avatar
Originally Posted by Alex_M
I've used three of the cheapest hubs I could find on eBay. One was bad out of the box and they replaced it no questions asked. I haven't had any other issues at all. 10/10 would recommend.
What brand was your ebay. or seller at least?
Old May 7, 2017 | 07:47 PM
Alex_M's Avatar
I'll look it up and see.
Edit: It was still in my watch list in case I ever needed another. Just under $70 and a 10 year warranty.
http://www.ebay.com/itm/371108417365...%3AMEBIDX%3AIT
Also, the front and rear are the exact same hub. I've used this one in both locations. You just need to move your o-ring over from your old hub or get a new one. The ABS sensor is longer on the front hub, but if you're lifted this works to your advantage and if you're not lifted then you can just zip tie a little loop to take up some slack.
Old May 7, 2017 | 08:58 PM
usaf_disco's Avatar
i just realized they were the same. I replaced the front axle in my rover and the junkyard rig i ripped it from has the hubs just conveniently laying right there under it. Well i had the disassemble all that from the axle so they are laying there because of me. All i gotta do is go grab it no tools required. Hmmmm 20 bucks sounds good.
Old May 7, 2017 | 10:15 PM
Alex_M's Avatar
That it does. The only hub I haven't replaced on my Disco is one that the PO replaced with a used unit.
1badcj8
Apr 13, 2013 03:52 PM
wvujosh
Sep 30, 2007 11:40 AM
01 Discovery
Dec 1, 2006 12:07 AM
Tanrover
Nov 20, 2006 11:30 AM
masonstewart
Jul 17, 2006 02:32 PM
