Rear Pads And Rotors
Old Feb 28, 2011 | 10:22 AM
jpluncford21's Avatar
Default Rear Pads And Rotors
Anyone have any suggestions for rear pads and rotors. I just changed out the front pads and rotors (Akebono ceramics w/ EBC Sport rotors), and now it's time for the back....I'm just starting to get this truck dialed in to where I want it!
I've read differing opinions on ceramic pads, vented/slotted/dimpled/drilled rotors....THERE'S TOO MANY CHOICES!!!! thanks guys
Joseph
Old Feb 28, 2011 | 10:29 AM
Bundu's Avatar
Banned
Why not go with the same combo? I take it you are happy with the front?
I did akebono pads with plain rotors (not drilled slotted dimpled studded blinged) with stock tires and the brakes work very well.
Old Feb 28, 2011 | 11:38 AM
Default Same Set Up
Well....mainly bc the front set up was freakin expensive!! I was hoping to maybe cut the cost some without cutting the quality. But in the end I may suck it up and just go with the same setup. Just curious as to what setup everyone else is using
Old Feb 28, 2011 | 01:10 PM
Snafu / Disco Fries's Avatar
Joseph
Stick away from anything drilled or slotted unless you are spending big money on a professional set. They lose structural rigidity and offer no real advantages. I have the Akebono and they do a good job. Brake dust is high and they are a bit noisy, but good initial bite.
cappedup
Oct 1, 2015 01:22 PM
RITTER
Aug 24, 2012 03:16 PM
ewok
Aug 18, 2010 02:03 PM
