Rear Propshaft Removal Help
Old Jan 14, 2013 | 04:02 PM
  #21
TRIARII's Avatar
Originally Posted by threalassmikeg
Lol he used the Blue Wrench....
Honestly I've never had one spin on me but I use an impact to remove them.
The land rover part # for the bolts is FRC3602 3/8x24x1 3/4"
The nyloc nuts NZ606041L
The 1/4" difference as was suggested earlier 1 1/2" may be the difference of the overall length.
The reason he is removing the driveshaft (which I suggested) is to check the park brake drum set screw.
I've seen this too many times (as many times as front driveshafts were replaced for the wrong reason) where the screw vibrates out then presses on the driveshaft flange causing a slight to severe driveline vibration . It's not always the case, but it's the right way to diagnose this issue based on the symptoms given, If it's loose and the vibration is fixed he's saved himself 300-400 for the time being. And the money saved can be spent on somthing else equally important(like a new brake booster)
If it's not fixed THEN a front driveshaft would be in order.
I'm only trying to help keep the priorities in order here.
And I appreciate it very much!!!! Just want to make sure Im getting the correct hardware for the job, so the part numbers you provided are very useful!
Old Jan 14, 2013 | 05:11 PM
  #22
fishEH's Avatar
It's a standard hex head bolt. You're really over thinking this. Like I said, hop on
Mcmaster.com and order up some grade 8 nuts and bolts. Should run about $10, and you'll have extra for later use or your friends.
Old Jan 14, 2013 | 05:34 PM
  #23
TRIARII's Avatar
Mind linking me to the specific nuts and bolts from Mcmaster, that will fit my Disco? I dont know **** about measurements and all these tools/hardware. I just see a bolt and try to visually match it lol.
Old Jan 14, 2013 | 10:00 PM
  #24
fishEH's Avatar
Nuts, part #97135A235
Bolts, I don't recall the exact length. I thought it was 1.25" but others have said 1.75".
Links with McMaster don't work great, but their site is super easy to navigate.
Just remember Grade 8, 3/8"-24
Old Jul 26, 2013 | 09:27 AM
  #25
Vai2kdna77's Avatar
Default Nuts for new propshaft
So I want to be clear. I have all the said parts for the rebuild. What I do not have is the nuts. Should they be Nylock? I have seen posts for Grade 5 and Grade 8. 3/8" 24 TPI? Can someone please clarify this for me?
Old Jul 26, 2013 | 10:36 AM
  #26
NickAdams's Avatar
I used stainless steel nylock.
Old Jul 26, 2013 | 10:44 AM
  #27
drowssap's Avatar
definitely nylocks
Old Jul 26, 2013 | 12:55 PM
  #28
earlyrover's Avatar
"are the nuts nylocks like the ones used on the front drive shaft? (a nut with plastic threads)
If so you should be able to heat the nuts hot enough to melt the nylon enough to pull the nuts off."
Bunk, ain't so. nylock nuts have that nylon only on end of nuts, that functions to lock the nut, rather than using a lock washer, with steel threads otherwise on remainder of nut, so melting the nylon will not allow them to be pulled out with any ease
To remove the nuts from the moving bolts, do as I did, and put an open end wrench on the head of the bolt, and a boxed end wrench on the nylock nut, and turn it off. Don't use pair of open end wrenches, as you are likely to round off corners of nuts. Worked for me!!!
Old Jul 27, 2013 | 06:42 AM
  #29
antichrist's Avatar
Also use 6 pt box end wrenches, not 12 pt.
TRIARII
Feb 4, 2013 11:03 AM
TRIARII
Jan 29, 2013 09:25 PM
AuZZZie
Mar 13, 2012 06:58 AM
Robover01
Nov 19, 2009 08:25 PM
ianzx6r
May 5, 2009 04:10 PM
