rear sub connections
Old Aug 13, 2013 | 11:36 AM
parkerlander's Avatar
Default rear sub connections
Going through this 99 disco II and doing a bunch of oddball stuff.
Have the subs off and have read the Rave on what colors go to what speaker but I have this on the receiving end and am at a loss how it's connected?
ends coming out of door (which I have and is correct) : (rave) pink & black stripe ( looks white in pic but it's pink) & red & black go to one speaker. Brown & black and white & black go to the other .
amp end is :bare silver, red, blk, blk, purple/yellow and green/orange.
Don't see any markings either if it's a HK or Phillips. I have the highline system also: "A" column tweets front , front door woofs and middles, back door mids and highs x 2 for a total of 12 speakers (including the rear).
Thanks as I am re-doing the whole system!
Attached Thumbnails rear sub connections-woof1.jpg   rear sub connections-woof2.jpg
Old Aug 13, 2013 | 11:50 AM
ralphobell's Avatar
What exactly is your question? I'm a little confused.
Old Aug 13, 2013 | 04:12 PM
I found all the wires cut and just sitting in door . P.O. did all sorts of BS.
"and am at a loss how it's connected" ?
what wires go to what? connect the two pics I can not find any other wires in the door. Seems like there should be a power and ground to operate the sub amp ?
Old Aug 13, 2013 | 04:20 PM
ralphobell's Avatar
The wires that were left in the door from factory originaly had a connector on the end I believe that plugged into the rear speaker box. I don't believe it ever supplied power there.
From what I can tell, the PO never hooked those speakers up. Maybe when he realized he didn't have power, he abandoned the job.
Old Aug 13, 2013 | 04:36 PM
ok I'll have to fiddle around with it and see if I can make anything happen.......
fezzr
Mar 18, 2012 12:20 AM
Arizona man
Nov 20, 2010 05:16 AM
juan_kerr
Apr 21, 2009 12:48 AM
apcollin
Sep 21, 2007 11:07 AM
rovernbama
May 15, 2006 03:03 PM
