Sponsored by: CARiD
Rear Sunroof problem Discovery II
Old May 22, 2010 | 05:59 PM
davidlafrance's Avatar
Default Rear Sunroof problem Discovery II
I swapped the front and rear motors...rear doesn't work no matter where it's hooked up, so I can assume it's dead. Putting a switch that I know works on the rear port and putting the good motor back there and I get nothing. But the rear switch works on the front panel. Any suggestions? Anyone have a cheap sunroof motor I can buy?
Also, can anyone tell me what this item is that I've attached photos of? It appears to have a black ground wire that is not attached to anything.
Attached Thumbnails Rear Sunroof problem Discovery II-2010-05-22-16.41.07.jpg   Rear Sunroof problem Discovery II-2010-05-22-16.41.30.jpg
Old May 22, 2010 | 08:05 PM
roving patrol's Avatar
maybe a dead fuse?
Old May 23, 2010 | 07:54 AM
ibis1's Avatar
Talking What is it?
That is the receiver for your handset (remote) that relays the signal to the alarm/central locking system to lock/unlock or arm the vehicle. ibis1
Old May 23, 2010 | 12:23 PM
thanks...
the fuses in the passenger box looked fine...if it were a fuse wouldn't both of the sunroofs be out?
Old May 23, 2010 | 10:53 PM
some of them may not share the same fuse! could be separate!
Malcohmh
Sep 21, 2014 10:02 PM
BigRed98
Jun 21, 2010 12:30 AM
00discosd7
Dec 27, 2007 07:08 PM
tym2brn
Oct 30, 2007 02:09 PM
christer
Freelander
Oct 28, 2006 03:47 PM
