Rear Sway Bar Removal
Old Feb 22, 2008 | 03:40 PM
sailorcolin's Avatar
Default Rear Sway Bar Removal
How is the on road ride of a disco 1 with the sway bar removed for off road use? Also how much more articulation do you get with it removed, with stock springs and shocks? And is it worth it with a car with factory springs and shocks?
Old Feb 22, 2008 | 03:52 PM
Default RE: Rear Sway Bar Removal
If you have a new lift and the suspension is firm enough, you could remeove it and gain some articulation. If you haven't changed your suspension it will be a swaying mess.
Old Feb 22, 2008 | 06:32 PM
llesra's Avatar
heres a couple of pics comparing with/without sway bars. white disco has 3" lift with ome shocks and the red has 4" lift with bilstein 7100s. with stock suspension, you should just leave them in.
https://landroverforums.com/fb.asp?m=37971
Old Feb 22, 2008 | 07:20 PM
Great comparison pictures Arsell. Your red Disco is looking so good.
Old Feb 22, 2008 | 10:46 PM
llesra's Avatar
thank you mike!
deer4011
Jan 12, 2021 07:10 AM
toofaroffroad
Aug 29, 2013 12:25 PM
AdrenalinPlease
Dec 26, 2012 12:22 PM
GARovee
Apr 16, 2010 04:43 PM
Speed racer
Nov 11, 2009 09:44 AM
