rear sway bars?
Old Mar 6, 2011 | 11:25 PM
sloppyjoe's Avatar
Default rear sway bars?
have noticed a clunk sound from the rear when i leave from a dead stop. as i was changing oil today i got on the creeper and checked the shock bolts, drag bars etc.
turns out the driver side link from the swap bar is shot and has a little bit of play in it. its the link bolted to the diff. so i guess when the truck shifts weight onto the rear the link moves and makes a slight clunk sound.
tried to tighten it and its just spinning. shot!!!
so do i go through the effort to replace the link or are the rear swar bars even needed?
Old Mar 6, 2011 | 11:51 PM
mwindth's Avatar
Hey sloppy...quoting RAVE pg. 815: " The anti-roll bar is an essential part of the rear suspension."
Old Mar 7, 2011 | 12:05 AM
sloppyjoe's Avatar
thats lawyer rubbish!
i asked justin at lucky8 when i ordered my suspension if the rear sway can go and he said yes many guys do remove the rear completely and add front disconnects. but he stressed that he can not recommended to do a rear sway delete.
so i was curious if anyone has just dropped the rear sway.
Old Mar 7, 2011 | 12:11 AM
mwindth's Avatar
true, very true...
Old Mar 7, 2011 | 12:33 PM
handsome rob's Avatar
In my limited and useless opinion, if you tow at all I would keep it. It will help with lean while on the road but over all your front is doing most of the work. If you do tow then you want that little extra help in keeping it pointed in the right direction. Take it off and see what you think of the feel, do some emergency stops while driving fairly slow and see the difference, then you can decide if it is for you or not.
Old Mar 7, 2011 | 01:09 PM
hilltoppersx's Avatar
mine are coming off along with the front's, but i have HD springs and nothing on my truck, no steel bumpers, no winch, not even back seats. its stiff enough.
devildog just took his front and backs off and he said it's like driving a Cadillac but we both have DD that are not our truck. I wouldn't reccomend it for a DD or like said above if you're towing.
Old Mar 7, 2011 | 03:02 PM
Sbonomo's Avatar
I have been running with no front or rear sway...I would not recommend for anyone that drives over 45 mph. My rig i literally all over the place. I have a 2 mile commute to work where i rarely go over 30 mph so i decided that i was ok for my situation to take them off. I will note that anything over 65 or so is borderline scary. However, i am very pleased with the added performance on the trail.
deer4011
Jan 12, 2021 07:10 AM
MiamiC70
Jun 21, 2011 02:07 PM
oysterhead
Apr 6, 2010 11:31 PM
Speed racer
Nov 11, 2009 09:44 AM
lipadj46
Aug 25, 2009 08:39 AM
