Rear wheel hub assembly question.
Old Apr 11, 2021 | 12:24 PM
Black.Rhino's Avatar
Double check the axle vent, disconnect and blow it out with compressed air...nine times out of ten...plugged and it causes leaks at o-rings.
Roger that.
Old Apr 11, 2021 | 12:25 PM
Originally Posted by zski128
Coat the o-ring with a little vasoline on reassembly to prevent it from pinching. Clean off the axle matting surface as best you can so the bearing sits flush as possible.
Copy.
Old Apr 12, 2021 | 12:29 PM
I was reading another thread on torque settings and I read that the torque setting for the castle nut is something like 365 ft lb or 490 nm? I was wondering how do you ensure that the castle nut lines up with the axle notch so that you can peen it? Or is it any part of the castle nut can be peened into the axle notch?
Also, is it really necessary to get it to 365 ft lb? I have a torque wrench that goes up to 355 foot pounds Is that extra 10 ft pounds really necessary? I'm not really into buying another torque wrench but I will if I have too.
Old Apr 12, 2021 | 02:33 PM
Originally Posted by Best4x4
Front ABS sensors in the rear = no extensions needed as they are longer vs stock rear units. I recommend that on any lifted D2 that flexes off road. Option B is also something that all LR D2 owners should do as it helps greatly narrow down issues with the ABS/TC/HDC system.
I just spoke with British Pacific in Simi Valley and they said they can't confirm that the only difference between f&r is sensor length? Best4x4 your absolutely positive beyond the sensor cable length they are identical?
Old Apr 12, 2021 | 03:00 PM
Best4x4's Avatar
Yes my 99 & 02 Kalahari are both running front ABS sensors in the rear. Sensor itself = identical, only difference = length of wire and a few little rubber grommets ment for routing it thru the front fender (you can carefully cut them off if you want it to look cleaner).
Old Apr 12, 2021 | 05:19 PM
Thanks for the confirmation. Friday I'm heading over to Simi Valley to get the front bearing assembly. I'll probably just keep the rear as a backup out on the trail.
TRIARII
Dec 21, 2017 05:57 PM
Externet
Aug 26, 2013 06:45 PM
marshman442
Jun 15, 2011 07:12 PM
Disco_Fever
Mar 3, 2011 11:38 AM
Torancis_LR
Apr 13, 2010 07:44 PM
