Rear Window Channel Seals Replacement - Fixed
I wanted to share my fix for the rear door window channel seals. These are the seals that the glass window fits into. New replacements are nowhere to be found and I tried for some time to get a decent set of used but was never successful. Mine had deteriorated where they would let a lot of wind noise and any water sprayed on the window in. On the front and top of the rear windows I used the seal for the front window that you can still find new. Believe I purchased from AB or Rovers North. Just one seal is enough to do both rear windows. Had to make some cuts in the middle of the seal to fit the corners. For the rear part of the window the channel is smaller and I was able to find the following seal that was a pretty good fit. No longer have the wind noise or water leaks!
Manufacturer C.R. Laurence Part Number AS134096 Item Weight 1 pounds Item model number AS134096 Color Black
Search the following on Amazon.
CRL Flexible Flocked Rubber Glass Run Channel for 1963-1967 Ford and Mercury, 1966-1971 Fairlane and Comet and 1972-1975 International Truck - 96 in
The following 6 users liked this post by 04disco2va:
acg (09-08-2021),
H Hill (09-09-2021),
jfreez (09-09-2021),
Mntnceguy (09-15-2021),
The Deputy (09-08-2021),
and 1 others liked this post.
