Rear windows won't roll up
Old Sep 10, 2004 | 09:57 PM
95discotn's Avatar
3rd Gear
Default Rear windows won't roll up
I have a 95 Discovery. My wife rolled the windows down today and they won't go back up. I checked the fuse, it was fine. I hooked two wires to a rechargeable battery, then held it on the wire going into the door and rolled the windows up. Anybody have any suggestions as to what to check next?
I also noticed the rear windshield wiper will not operate now. I checked the fuse for this also. It was fine. Any suggestions on this also?
Thanks
Marty
Old Sep 15, 2004 | 04:16 AM
Lighting90's Avatar
Default RE: Rear windows won't roll up
It sounds like an earth fault, check all earth points around the the vehicle, the connections have a habit of becoming a lump of rust and falling off.
It is worth undoing all earth points you find and cleaning them up with sand paper, anyway while you are on, to help prevent other problems in the future.
Old Oct 13, 2004 | 09:28 PM
95discotn's Avatar
3rd Gear
Took circuit board out from behind glove box. Sure enough, bad solder points. Resoldered and now all is fine.
Rear wiper started working day after it stopped and hasn't stopped since.
slamwhit
Apr 20, 2017 12:26 PM
txjag1023
Mar 9, 2012 12:27 AM
SC Rovergirl
May 15, 2010 07:06 AM
01DiscoII
Apr 9, 2008 01:02 PM
95discotn
Oct 13, 2004 09:28 PM
