Rearview mirror removal?
Old Oct 20, 2010 | 04:53 PM
dcarr1971's Avatar
Default Rearview mirror removal?
OK...according to the RAVE it looks like the auto-dim rearview mirror on my '99 D2 should just slide down and come off. Is there some trick I'm missing here?
I don't want to whack it for fear of cracking the windscreen, but it sure doesn't seem to be moving otherwise...
I'm trying to replace it since it doesn't auto-dim any longer. From what I can see, there is no way to access the clamp holding the existing mirror in place. (The replacement appears to be identical to the one I'm removing.)
Last edited by dcarr1971; Oct 20, 2010 at 04:56 PM. Reason: providing a little more info.
Old Oct 20, 2010 | 05:02 PM
mwindth's Avatar
Check this thread: https://landroverforums.com/forum/sh...t=spike+mirror
Old Oct 20, 2010 | 06:37 PM
I do not know about the DII mirror, but the DI mirror you have to twist 90* and then pull it off.
You could always take it to a glass shop and have them take it off.
Old Oct 21, 2010 | 12:25 PM
dcarr1971's Avatar
Default Success!
Thanks for all the input guys!
The rearview mirror removal for the DII is definitely different from the DI. No twisting was required, just firmly pulling the mount down toward the bottom of the windscreen along the contour of the glass.
I detached the overhead bins and pulled the light and sunroof switches so that I could more easily access the clip holding the mirror's connector. After a quick test to confirm that the 'new to me' mirror was functioning, I re-attached everything and
Thanks again!
Noel
Aug 4, 2008 06:09 AM
PITTDISCO
Mar 9, 2008 07:39 AM
caga10
Jul 12, 2007 11:00 AM
cpl55
Apr 20, 2007 01:06 PM
chemeguy
Mar 11, 2005 11:35 PM
