Rebuilding Steering Box
Old Feb 5, 2022 | 07:27 PM
cvhyatt's Avatar
Default Rebuilding Steering Box
Got a couple of leaking steering boxes that are sitting around. Since I am pretty much done with the rover, I thought I would learn how to repair them. There seems to be varying degrees of rebuild kits out there. I don’t plan to do major overhauls- just replacing seals I think.
Atlantic British has a cheap 3 seal kit for $22 but there are ones on eBay that have quite a few more parts to them. Which should I get?
https://www.roversnorth.com/parts/qfw100140_seal_kit_steering_box_discover_ii_main_s haft
https:/www.roversnorth.com/parts/qfw100180_seal_kit_output_shaft_power_steering_box _discovery_ii
https://www.ebay.com/itm/LAND-ROVER-POWER-STEERING-GEAR-BOX-COMPLETE-REPAIR-KIT-DISCOVERY-2-MR0080-ADWEST-/182624404253?mkcid=16&mkevt=1&_trksid=p2349624.m46 890.l6249&mkrid=711-127632-2357-0
Old Feb 8, 2022 | 07:23 PM
Karmakannon's Avatar
After looking under my discovery last night I was pondering much the same as you. Most things on these vehicles can be rebuilt so I'd imagine the steering box can't be all that hard can it? Somewhere between a wiper blade and a frame swap I'd suppose haha.
Old Feb 8, 2022 | 11:46 PM
JohnZo's Avatar
The steering box rebuild steps are covered in the workshop manual. I bought a whole set of parts, including that little nylon tipped seal set screw that costs over $20 by itself. That was on my first truck, so I was in learning mode, and PS fluid was everywhere. The procedure is easy enough, and I learned how it all works, and the adjustments (it takes a touch).
For my second truck I left it alone because it was more effort than I wanted to spend, for little benefit. I just put new hoses on it, and it's been great. It really depends on what you want. Read through the manual, then decide.
Old Feb 9, 2022 | 10:09 PM
acg's Avatar
acg
This is $489 remanufactured with no core charge. Has anyone used them?
The seller lists them on this webpage as for the 2003-2004. Are steering boxes different between the 1999-2002 and 2003-2004?
https://www.ebay.com/itm/16298168557...kAAOSw0NlbkFkX
Old Feb 10, 2022 | 01:27 PM
cybercop's Avatar
I found this on BAP
Pump and Box
Is there a clear "Better" Remanufactured/Refurbished supplier?
Don't want to buy used as the supplier can't be sure it wasn't leaking before it was taken out of the donor truck.
cvhyatt
Apr 2, 2021 01:47 PM
DiscoBlanco
Oct 13, 2014 05:21 PM
volture
Dec 2, 2013 08:59 AM
lostjohn
Nov 24, 2010 09:17 AM
Darover
Jun 30, 2009 02:37 PM
