Recovered from fire, up and running, but a few codes...
Old Jan 4, 2020 | 12:08 PM
DonRW2007's Avatar
Default Recovered from fire, up and running, but a few codes...
Hi. I posted a couple of months ago that a wiring harness on my D2 came in contact with the exhaust manifold, and started a small fire. It was quickly extinguished, and I’ve had the wiring fixed, as well as a new alternator and battery that were shot. Everything seems to be working, but the engine isn’t running quite as smoothly post-fire, missing or hesitating occasionally upon acceleration. I also have a few codes that won’t go away once I read/reset them:
62 Cannister purge valve fault
60 Purge cannister vent valve / DMTL power stage fault
73 MAF sensor fault
70 Camshaft sensor fault / valve timing error
i should mention that I read these with my Foxwell scanner so the code numbers may be funky...
The latter seems like a likely culprit for the hesitation. Seems to me I had an issue with this camshaft sensor in the distant past - is that the sensor that’s such a bear to get to and can cause the truck to shut off intermittently?
The others may be due to discharging a dry chemical fire extinguisher under the hood. Even though these modern extinguishers are supposed to be safe for electrical components, I am skeptical. Any ideas?
Thanks,
DRW
Old Jan 4, 2020 | 06:16 PM
XRAD's Avatar
What part of the harness got burned? Have any pics? What is a 'small' fire? Was the knock sensor wiring damaged?
uplndvpr
May 9, 2019 06:05 PM
KlamathMatt
Apr 9, 2015 08:58 AM
abran
Apr 6, 2015 07:19 PM
kmyer01
Jun 18, 2012 06:36 PM
AK Rover
Apr 22, 2009 08:23 PM
