Refoaming subwoofer HK speakers
Old Aug 2, 2020 | 11:52 PM
nashvegas's Avatar
Default Refoaming subwoofer HK speakers
(UPDATE down below, I did this, re-foaming was successful but the speakers still don't work...sigh)
My cargo door subs are toast / decayed on my 00 with HK. I was going to toss in the bin until I realized only the foam was bad and there is actually a way to "refoam" speakers. Who knew.
Link here
Before I am sure to waste a Sunday reforming speakers like a perfectionist, has anyone tried this? On your Rover or otherwise. And did it work? Or is it futile?
Unfortunately finding speakers that fit the tailgate is near impossible from my research.
Old Aug 3, 2020 | 06:39 AM
Alex_M's Avatar
Refoaming speakers is pretty common among audio enthusiast groups. Definitely not a futile effort, and shouldn't be all that difficult, though if you wanted to upgrade you should be able to find some 6.5" subs that would fit back in place with a little work.
Old Aug 3, 2020 | 11:07 AM
Tony Luna's Avatar
Interesting. I’m about to do the same for my HK subs.
Old Aug 3, 2020 | 12:52 PM
Discorama's Avatar
Have you checked out https://www.parts-express.com/cat/ca...-subwoofers/54 ? In case you want to put in new speakers, but they have re-foaming kits too.
Old Aug 3, 2020 | 03:47 PM
Tony Luna's Avatar
I put a pair of new 4 Ohm speakers in - they barely moved. I put in a set of OEM Philips speakers - same thing. I found an HK subwoofer assy at a Pick and Pull (with trashed foam rings) and put that in - the speakers actually moved in and out and produced more sound than the previous 2 attempts. I’ve tried to figure out what type of speakers (Ohms) originally came as subs for the HK system - no luck. I’m re-foaming.
Old Aug 3, 2020 | 05:36 PM
nashvegas's Avatar
BTW I messaged the ebay seller on the link I included earlier and they clarified that those foams are actually (technically) for the front door lower speakers "woofers".
Not necc the cargo door subwoofers.
I'm going back/forth w them with measurements. They want to be sure before I order.
Old Aug 3, 2020 | 05:42 PM
Extinct's Avatar
I have refoamed a couple sets, sounds much better.
Old Aug 3, 2020 | 08:11 PM
Frank4's Avatar
I replaced my rear door speakers with some pioneers many years ago. It can be done.
Old Aug 27, 2020 | 02:12 AM
RBlandy's Avatar
Default How did you replace the speakers?
how?? I’m trying to replace my front and rear door speakers. All four have gone out. I can’t seem to find any adapters that will enable me to screw the new speakers into the car.
Old Aug 27, 2020 | 03:33 PM
rhyslegge's Avatar
I just used the kit listed by the op, and the results were very good. Easy install, and they sound as new. Would recommend to anyone over trying to find replacements that are currently available.
Rhys
