Remote door locking problem
Old Dec 12, 2010 | 02:19 PM
sc_mark's Avatar
Default Remote door locking problem
I have not found this exact problem searching the forums, so here goes.
Daughter's 2004 D-II will not lock using fob. When fob used to lock door, horn sounds, but doors do not lock. I checked all the doors and re-checked, they are all closed completely. Fob unlocks all doors normally. I can lock all 4 doors by using dash lock button, then using key to manually lock driver's door when leaving the vehicle, so at least the doors can be locked.
Everything was working just fine until today.
Any thoughts? Is this a door lock actuator problem?
Old Aug 29, 2011 | 08:05 AM
ernestog's Avatar
I am having same problem. Did you ever find the problem?
Old Aug 29, 2011 | 09:14 AM
First, if a horn honks, all your doors are not completely closed, the one that is acting up may need a new lock actuator. So find the door that either isn't always closed all the way, has a bad door switch or bad actuator, this can include the tail gate and the hood.
Old Aug 29, 2011 | 09:22 AM
jafir's Avatar
Yeah what Mike said.
A recent post was that someone had some engine work done recently, and somehow the switch under the hood had gotten bent, and then he had the exact same symptoms you have.
Old Aug 30, 2011 | 06:54 AM
ernestog's Avatar
All my doors and hood are closed. I would think that its the drivers door because when I turn off my disco and open the drivers door the radio won't turn off all doors lock and unlock with inside lock and unlock switch. But I can not find the door pin
Old Aug 30, 2011 | 08:11 AM
It is not that the door is not closed but the switch does not see it closed.
Old Aug 30, 2011 | 07:46 PM
ernestog's Avatar
Where is the switch?
Old Aug 30, 2011 | 11:50 PM
lordmorpheus's Avatar
in the door lock motors.
I would copy from RAVE, but cannot copy and paste from my virtual XP machine because I haven't had the time to learn how, or get RAVE installed on my Linux box.
Old Aug 8, 2012 | 01:14 PM
DJWINK's Avatar
Hi! Did you find the problem? I am having the same exact problem. Please help me
Brian
ESPN
Sep 23, 2011 07:47 AM
bikeG976
Jan 2, 2010 03:38 PM
discorh
May 14, 2008 11:23 PM
mdvickst
Sep 3, 2007 03:12 PM
johanba
Apr 3, 2007 11:37 AM
