Removal of Front Drive Shaft Bolts
Old Oct 1, 2011 | 03:45 PM
antichrist's Avatar
Yes, you are correct, 3/8-24 and definitely grade 5 nuts on the old ones as you don't want to mix bolt/nut grades.
Old Oct 1, 2011 | 03:46 PM
antichrist's Avatar
Originally Posted by marshman442
Only one of the 4 needs to be replaced. The threads were damaged when I had to cut off the stripped nut. (see 1st post in the thread) I am thinking about only cutting the one with the damaged threads and feeding it from the other direction.
Sorry, I think I was reading two output flange threads back to back and got them mixed up.
Originally Posted by jayman
I found in another thread: steel grade 5 for 3/8" bolts w/ 24TPI
Can't confirm if that is correct because I haven't had the time to work on the Disco, but I did buy them already.
Old Oct 2, 2011 | 08:23 PM
marshman442's Avatar
ok, tried to loosen the 30MM bolt and wanted to make sure that I don't break something internally in the t-case or tranny. I noticed the RAV manual shows to use tool # LRT-51-003 to restrain the flange. I don't have this tool and wanted to know what others are doing, do you guys just put it in park and lock the trans in place then break the nut free?
I believe the bolt is torqued to 109 ftlbs so it will take some yanking on.
Anyone know the safest way to break this free w/o the tool? Or worse - breaking the tranny?
Old Oct 3, 2011 | 03:51 PM
groeder24's Avatar
I used an impact wrench to loosen mine. Torquing it was a different story as I don't like to use the impact wrench for any assembly.
Old Oct 3, 2011 | 08:35 PM
So I take it you did not use the reccommended tool to hold the flange in place?
Old Oct 4, 2011 | 06:45 AM
drowssap's Avatar
no real need with an impact gun, you should be able to hold the flange with your hand.
stb616
Nov 18, 2014 10:01 PM
Celto 4
Aug 22, 2013 07:43 PM
reddevildemo
Jul 1, 2009 01:21 PM
mcvickoffroad
Mar 6, 2009 09:02 AM
Hookerpat
Apr 4, 2008 12:25 PM
