Removed head, please help!
Old Jun 28, 2018 | 12:50 AM
No Doubt's Avatar
Pressure test the block. If that passes, then have your machine shop pressure test your heads (heads can crack internally). If that also passes, then have your heads decked, then use a new gasket on each side and button her back up.
Old Jun 28, 2018 | 12:55 AM
No Doubt's Avatar
Old Jun 29, 2018 | 08:41 AM
abran's Avatar
I’m saying cracked block
Old Jun 29, 2018 | 11:01 AM
OffroadFrance's Avatar
Useful vid ND, like .
The fire extinguisher system in my race cars was similar only it had multiple heads and was all plumbed into the engine bay and gearbox area and had a large gas bottle but manual initiation not automatic. A BIG red **** on the front externally to initiate the extinguisher usually by the Marshall's. It was mandatory on race cars and a scrutineers checked item every time. (They hated burned bodies at race meetings .............. so darned messy )
Old Jun 29, 2018 | 04:24 PM
No Doubt's Avatar
I strongly recommend *automatic* fire extinguishers in the engine bay of gasoline/diesel vehicles and covering the battery packs of electric ones.
Wrecks *can* under some circumstances knock out a driver, preventing Manual detonation of fire extinguisher systems.
In contrast, there are several inexpensive automatic fire extinguishers that are activated by heat melting an alloy metal or plastic trigger.
Those literally can NOT fail to spray in case of fire.
I've used Fire Foe and there is now an Elide ball that you can buy for about $80.
My signature here below also links to the unit I put into my daughter's 2003 Disco 2.
Broncoguy27
Jul 11, 2018 09:40 AM
Ben Matheson
May 4, 2018 05:57 PM
CaptainCulp
Oct 8, 2013 09:04 AM
jennifer
Nov 17, 2008 09:26 AM
Tastang
Nov 30, 2007 05:47 PM
