Removing 2nd row seats
Old Jul 17, 2015 | 12:49 PM
LR03NJ's Avatar
Default Removing 2nd row seats
Are there any special way to remove the rear seats? Will I be able to install it back easily? There are springs there which im concerned and just want to really clean the Disco completely. Thanks
Old Jul 17, 2015 | 03:32 PM
GROVERDISCO's Avatar
Default Seats
Super easy, just pull the carpet down to access the front bolts, remove those flip seat forward and remove back bolts. Pull out seats. Easier to take them out thru the back, especially the big one.
Good luck!!
Old Jul 18, 2015 | 08:17 AM
Broken08's Avatar
Took out the "40" yesterday. Took about 4 minutes.
I'm trying to think if there would be some way to make them quick release, but since the belts are part of the seat, probably not
Old Jul 18, 2015 | 08:39 AM
Alex_M's Avatar
I was thinking the same thing recently. Maybe drill out the threads, weld in some sort of pin a hwith ole in the end, and use a cotter pin or the ones used with a trailer pin through that? you'll want it tight though.
badassbmwm3
Jul 24, 2015 08:57 AM
j.dstasio
Nov 11, 2012 03:02 PM
Buzz
Aug 17, 2011 12:10 PM
kellyr
LR4
Aug 27, 2010 04:00 PM
kellyr
Aug 22, 2010 04:06 PM
