Removing 2nd row seats
Are there any special way to remove the rear seats? Will I be able to install it back easily? There are springs there which im concerned and just want to really clean the Disco completely. Thanks
Good luck!!
I was thinking the same thing recently. Maybe drill out the threads, weld in some sort of pin a hwith ole in the end, and use a cotter pin or the ones used with a trailer pin through that? you'll want it tight though.
badassbmwm3
Jul 24, 2015 08:57 AM
