Removing the crankshaft sensor. Help
Old Oct 29, 2013 | 09:11 AM
0304Disco's Avatar
You can remove the bolt that holds the Crank Position Sensor plug/metal attaching bracket to the head. You should be able to get this bolt off using an open end wrench probably 1/2 or 9/16. I will say it is difficult to see and the factory bolt for some reason is much longer than it needs to be, almost an 1" long and doesn't need to be more than a 1/2 in in length so I've replaced.
This will allow you to pull the wiring down from underneath the engine and actually see the connector to unplug.
You shouldn't need to disconnect anything.
Old Oct 29, 2013 | 09:16 PM
san988's Avatar
Y pipe is going down. After removing old sensor and placing new one I was unable to reach the two plug's end to get them connected. It is so frustrating. Y pipe will go down tomorrow (I should say will try to get it down).
Thank you so much for your replies.
Old Oct 29, 2013 | 09:39 PM
dr. mordo's Avatar
Did you see my post about long needle nose pliers to reach the connectors?
That was the only way I could do it.
Old Oct 29, 2013 | 10:10 PM
san988's Avatar
I bought a couple of the long neck but still there is not enough room (not for me).
Old Oct 30, 2013 | 01:23 AM
dr. mordo's Avatar
Sorry. That sucks.
Good luck with the Y pipe. I'm not envious.
Old Nov 5, 2013 | 09:16 AM
san988's Avatar
Ok just an update. Y pipe went down (easier than expected) so I got more room to play with the plug. It was still a pita to reach and plug it but now it is done.
Thank you to all
lrjon
Jun 7, 2020 04:13 PM
walkingzach
Feb 22, 2015 09:40 PM
jawsk99
Mar 19, 2010 09:54 AM
lipadj46
Nov 15, 2009 07:09 PM
smi8387
Feb 7, 2006 01:15 PM
