Replaced the cooling system, expected one thing, got another...
Yes I clearly understand that. That’s why I’m using a my launch scanner to determine my actual temps sent via ecu. I don’t take it kindly when someone is calling me ignorant!! Especially a senior member. I respect everyone, there’s no need to call anyone ignorant. We are all here to learn from each other, in my opinion. Smh!
Well 2nd morning of checking the coolant level right at the bleeder. Both times I’ve had to add coolant. And every time I have opened it I get a little hiss of air. Also I noticed my electric fan mounted on the condenser is not coming on. checked relay and fuse. Also connected Ddm to fan connection and it has 12.78 volts present. If I tap it it’s starts moving slowly. So I’m definitely getting that fixed before you any further.
