Replacement or continue the suffering?
Old Feb 26, 2014 | 10:28 AM
ZGPhoto's Avatar
Originally Posted by Ghaniba
ZG: After having lockers in previous rigs, I really do appreciate them more now that I'm not locked. ARBs front and rear are on my list of to-do whichever direction I head. Momentum also can break more things. That day was really more of a test run.
Coors: I'm not sure which hill in specific there was question to. The rock face - no. The first hill in the vid, yes, but on the left, easy path instead of the middle.
Awesome to hear that you can find a 2004 without sunroof(s).
Do the trucks out of the salt belt get corrosion on wiring in Rovers or is this only a New England thing? I'm wondering how terrible a wiring harness swap would be on one of these trucks.
Dave
Go with Ashcrofts.
A wiring harness swap would be awful, and most of the corrosion happens at the connectors so you'd be better off replacing those.
Old Feb 27, 2014 | 05:25 AM
Ghaniba's Avatar
Originally Posted by Dave03S
Related question, when one has the above mentioned ABS faults does the traction control even work? Or is he running without TC?
In short, no traction control. If it can't sense the actual rotation of tires properly, it has no way to really know if one wheel is spinning.
With that said however, it CAN still function on one axle and not the other -- it does it's best job it can. For example - in the ice and snow currently if I mash the brakes, the front abs is still functional, while the rear isn't due to my bad wheel sensor on the right.
Another tidbit -- When your truck is in low range - press the mode button on the trans and verify your electronics believe you're in low range - That also makes quite a big difference. If the high/low range sensor switch isn't working, it'll put it in and out of sport mode, instead of manual. I replaced my high-low sensor switch with a toggle in the cab. Now, I can flick it back to high range electronics wise and shut the truck off without having the system go into its fits about turning on already in that mode.
Dave
Old Feb 27, 2014 | 05:29 AM
Ghaniba's Avatar
Originally Posted by ZGPhoto
Go with Ashcrofts.
Why ashcrofts over arb?
And yep, that's where the majority of my wiring nonsense is -- in those blasted connectors they used to join all the wires.
Dave
Old Feb 27, 2014 | 09:02 AM
ZGPhoto's Avatar
Ashcroft took ARB's design and fixed all the potential issues. More gear engagement, no rotating air seal.
Old Jan 15, 2015 | 02:40 PM
Ghaniba's Avatar
Sorry to dig up an older thread -- but I still do have a question.
The corrosion on the wiring (connectors mainly) that I suffered in my first Discovery2 -- Does that happen on a truck from the south?
I ended up dumping my truck for a nice low price. I got tired of chasing the electronics. The kicker for me was the sometimes working OBD2 port... When I can't run my scan tools to even find OUT what the next error is -- I'm done.
So, now I'm on the hunt for another one. In a perfect world, I'll find a 2004 without sunroof(s) completely rust free and a blown motor.
Dave
Old Jan 15, 2015 | 02:55 PM
ZGPhoto's Avatar
DiscoWeb Message Boards
bam
bennyb43
Nov 28, 2015 04:01 PM
Ghaniba
Apr 10, 2014 07:21 AM
paul rod
Oct 25, 2011 09:19 AM
salve7
Nov 17, 2009 05:43 PM
