Replacing E-Brake Lever... How?
Old Jun 30, 2020 | 01:12 PM
erisidae's Avatar
Default Replacing E-Brake Lever... How?
Hey everyone,
I'm in the middle of restoring my first Rover and so I've been getting stuck on some pretty basic things. The obstacle of the day: the parking brake!
I'm switching the center console and parking brake lever, shift ****, etc for replacements that I found at a junkyard. Looking at the parking brake lever, however, I have no idea how to separate it from the wire!
I've undone the two bolts at the base of the lever, and now I see there's a rubber grommet that seals the lever to the actual wire that runs under the car. On the wire are two nuts. How do I go about this? There's no material online that I can find, and I don't want to just wing it because the e-brake is kind of crucial. Thanks in advance!
Basic anatomy of the wire from the cabin
Old Jun 30, 2020 | 02:59 PM
Best4x4's Avatar
Gotta pull the rubber grommet out. Then Ebrake handle will free.
Old Jun 30, 2020 | 04:13 PM
erisidae's Avatar
I tried, using a pair of pliers to pull from the top. Only succeeded in tearing it a little bit. What method should I use to pull it out?
Old Jun 30, 2020 | 06:53 PM
Best4x4's Avatar
I would leave the ebrake assembly mounted to the vehicle and then crawl under it and yank down on the ebrake cable. If that doesn't work use a small pick to get the rubber lip into the ebrake hole and then yank it out from the bottom.
Old Jun 30, 2020 | 08:48 PM
erisidae's Avatar
Great call - worked like a charm! I had someone sit in the driver's seat and push the lip with a flathead while I pulled. Took nearly no effort. Thanks a million.
Old Jul 1, 2020 | 08:17 AM
Best4x4's Avatar
No problem at all
tturner
May 5, 2017 07:01 PM
mnsledder
Oct 22, 2013 08:07 PM
SSL9000J
Feb 16, 2013 09:20 AM
UpChuck
Aug 20, 2010 09:41 PM
bluedevil
Jun 24, 2009 04:07 PM
