replacing ecu (main computer)
Old Nov 27, 2019 | 12:28 PM
  #41
Best4x4's Avatar
If it was the CPS this whole time you now know which 2 mechanics NOT to take it to in the future.
Old Nov 27, 2019 | 12:36 PM
  #42
Richard Gallant's Avatar
@Gary Archer man I feel for you that is just sad, every modern vehicle has the equivalent of a CPS. The symptoms are always the same everything works but no spark, generally you get warning but like you I did not.
Still a bunch of reading on this forum, plus suggestions and got me sorted.
Old Nov 27, 2019 | 12:48 PM
  #43
Sixpack577's Avatar
That was quick, lol
Old Nov 27, 2019 | 01:38 PM
  #44
Llamasayswhat's Avatar
Have you ever had someone actually scan it with a shop level high end scan tool? OBD dongles and even the moderately advanced scan tools cannot access all systems
I have seen several cars with a crank, no spark condition that was caused by an issue with the security system. There is a ground failure off the BCM that happens that will essentially stop the car from deactivating the immobilizer and authorizing spark. You will need a security capable scan tool to read that system.
The ECU can also have a similar ground control loss that will cause the coils not to light off correctly. You can usually clean grounds on that circuit to help with that.
Not everything on these cars is garage capable, you may need to bite the bullet and find someone who is an actual rover specialist, not someone who "works on rovers"
EDIT: Late to the party, looks like you figured it out
Old May 18, 2021 | 11:03 PM
  #45
Ryan Wolfe's Avatar
Default Can someone please tell me where to find the ecu on a 04 land rover range rover hse?
Apparently we have torn the dashboard out and we can't find it we have searched everywhere and no k e seems to gave any clue..
Originally Posted by abran
mollusc is right. I had a vehicle take 2000 miles for the last redness monitor to clear. Now when I have a stubborn one I first rest adaptions. If it's still stubborn I re load the software on the ECU.
It normally takes 50-100 miles of mixed highway and street driving for all monitors to clear, sounds like maybe you didn't drive it enough.
Old May 18, 2021 | 11:50 PM
  #46
@Ryan Wolfe wrong forum but here https://www.rangerovers.net/threads/...e.43067/page-3
Old Dec 13, 2024 | 10:26 AM
  #47
skipjack452's Avatar
3rd Gear
did you get an angers unit NNN500020 reprogrammable / usually a braker will have a discovery, normally (unless some has locked it) they require nothing more than installing and cranking the car.
Old Jan 10, 2025 | 08:57 PM
  #48
amoody's Avatar
5th Gear
Originally Posted by Gary Archer
It was the cps
no way.... so what did you do to discover this? I'm facing the same issue... but i've replaced my CPS twice now in case the first one was a dud
no spark, no fuel injection pulses either.... thought it was the ECU after that. put in a used one jsut like the other guy haha - now i know its not plug and play. should've read this thread before dropping so much money on the ECU....
Roflcopter
Jul 19, 2021 03:06 PM
toofaroffroad
Nov 24, 2015 06:50 PM
markle0258
Aug 25, 2014 03:21 PM
willys_49
Nov 10, 2012 07:42 AM
twmj1953
Feb 3, 2011 08:05 AM
