Replacing flex plate/flywheel on 04' Disco. have questions
Old Aug 28, 2013 | 10:52 AM
cobbcj7's Avatar
Default Photo
Originally Posted by Disco Mike
Just curious, why do you think you need to replace the flex-plate.
If you are going in there, don't forget to replace the engines rear main seal and the front tranny seal.
Because after the major leak devloped under the bell housing, and it was red transmssion fluid, I pulled the inspection plate to the bell housing and found a huge chunk of metal.. Assuming its flywheel, but wont be sure until I have it completely taken apart... getting close..
Again the truck grinds in park and won't engage any gears, so its pretty clear that the Torque Converter and Flywheel/Flx Plate are no longer connected..
Attached Thumbnails Replacing flex plate/flywheel on 04' Disco. have questions-img_20130824_114037_697.jpg
Old Aug 28, 2013 | 11:15 AM
drowssap's Avatar
have you started it with the inspection plate off, to see if you can see what is going on or not depending on the case.
Old Apr 10, 2014 | 11:58 AM
cobbcj7's Avatar
Here are some pics of the busted Flexplate for my truck...
So when I find my weight on the harmonic balancer, do I just make sure that my flexplate weight is aligned with it??
Attached Thumbnails Replacing flex plate/flywheel on 04' Disco. have questions-img_20140404_125636_943.jpg   Replacing flex plate/flywheel on 04' Disco. have questions-img_20140404_125627_525.jpg
Old Apr 10, 2014 | 01:17 PM
cobbcj7's Avatar
So I found my weight to be 10g on the Harmonic Balancer..
Is the weight supposed to be on my flex-plate or is it located on the fly-wheel?? I can't seem to find it on the flex-plate..
My Fly-wheel is in good condition so I don't need to replace that, so does that mean i just bolt up a new torque converter and flex-plate to the flywheel and not worry about weights?
I just went out and felt around my Flywheel and don't feel any weights on it..
Last edited by cobbcj7; Apr 10, 2014 at 01:27 PM. Reason: Updating as I check for stuff..
Old Sep 7, 2016 | 01:50 PM
toofaroffroad's Avatar
I see this is man old one but any closure or follow up? i'm about to jump into this job myself.
hcritz
Apr 26, 2020 07:48 PM
hhalimi
Jul 3, 2019 02:50 PM
rasch_C
Dec 22, 2012 01:47 PM
Spike555
Jun 2, 2009 11:19 PM
