Replacing Fuel Injector Seals-need advice
Old Jun 23, 2015 | 06:56 AM
  #91
Andy2Rover's Avatar
Yup! Exactly what I needed. Just about done rebuilding the injectors, have to remove those 2 broken bolts, then everything goes back together....
Old Jun 23, 2015 | 07:21 AM
  #92
MPDano's Avatar
Will you replace the gaskets as well? Valley, intakes?
Old Jun 23, 2015 | 08:54 AM
  #93
Andy2Rover's Avatar
Not as brave as you MPDano....only doing the bare necessities. I thought about the valley pan and valve cover gaskets "while I'm in there", but chances are I will make something worse and they dont appear to need to be changed right now.
Spark Plugs and wires were the only additional things I did.
Old Jun 23, 2015 | 10:16 AM
  #94
MPDano's Avatar
That valley, etc can be a source of leaks too. The valve covers were just a while I was in there, plus they were in the kit I bought.
Old Jun 25, 2015 | 10:51 AM
  #95
Andy2Rover's Avatar
Quick update.....
Left hand drill bit no workey for broken fuel rail bolts. Looks like I will have to drill them out and Helicoil it. Will probably do it over the weekend. Simple original job turning into a PIA!
Old Jun 25, 2015 | 11:11 AM
  #96
MPDano's Avatar
Quick update.....
Nothings simple when working with used cars. It's more of a patience game. Keep at it.
Old Jun 28, 2015 | 09:02 AM
  #97
Andy2Rover's Avatar
Another question guys.....I think I pulled a boner. I realized after I had drilled out the broken bolts for the fuel rail that I hadn't plugged up the injector holes, and metal shavings from drilling went in there and I'm assuming into the combustion chamber? Am I screwed?
Old Jun 28, 2015 | 09:16 AM
  #98
abran's Avatar
Fish a magnet in there, then finish with a shop vac. You should be fine.
Old Jun 28, 2015 | 10:15 AM
  #99
MPDano's Avatar
Yup, there is a telescopic magnet pick up at harbor freight for super cheap. Then pull all the plugs out and remove the fuel pump relay and turn the car over for a few seconds, the compression will blow out the shavings out the hole.
Old Jun 29, 2015 | 04:13 PM
  #100
Andy2Rover's Avatar
Ok, it's all back together! Took it back and forth to work today, about 50 miles, and no CEL. Calling it a win! Thanks for everyone's help, especially MPDano!
