Replacing Fuel Injector Seals-need advice
Old Jun 15, 2015 | 07:45 PM
  #61
MPDano's Avatar
Good news: Found the coolant leak. I forgot to tighten down one of the top hoses clamps.
Bad news: P0171 and P0174 returned.
Most def runs better. I am thinking it's the MAF and/or Post O2 Sensors.
Ughhhhhhh!
Old Jun 15, 2015 | 09:21 PM
  #62
MPDano's Avatar
Had a loose clamp on the MAF. Cleaned up the MAF again. Put silicone on the o-ring and tightened up the clamps.
Reset codes and drove around. Even took it for a car wash, so far so good. Driving it to work tomorrow as it is not ready per ODB reader.
Wish me luck!
Old Jun 16, 2015 | 06:58 AM
  #63
Andy2Rover's Avatar
Sounds like you might have done it! Let us know......oh and good luck!!
Old Jun 16, 2015 | 09:41 AM
  #64
jamestfl's Avatar
great write-up and the engine looks awesome! thanks for the posts. btw- what did you use for your battery source when cleaning the injectors?
Old Jun 16, 2015 | 09:50 AM
  #65
drowssap's Avatar
looks like he had a small motorcycle battery on the bench, a lot of injector will open with a simple 9 vt battery
Old Jun 16, 2015 | 03:41 PM
  #66
Motorhead1's Avatar
If your post cat O2's are throwing codes, they are doing their job, you probably need cat's. Watch your live data with your reader, your rear O2's need to have a steady voltage flow, not voltage jumping all over the board.
Old Jun 16, 2015 | 05:32 PM
  #67
MPDano's Avatar
I used a 12v ATV battery that I had laying around. Nothing special.
Old Jun 16, 2015 | 07:55 PM
  #68
MPDano's Avatar
Success! Put about 70 miles on it on the highway as well as street. No check light. Ran the status on my odb reader to make sure it was ready for smog. Once verified, I immediately took it to my smog guy. She passed!!
I'll chime back in after a few weeks if the CEL stayed off or came back.
Attached Thumbnails Replacing Fuel Injector Seals-need advice-smog-6.16.2015x.jpg
Old Jun 16, 2015 | 08:37 PM
  #69
Andy2Rover's Avatar
Great news! Thanks for all the info. I ordered all the parts and will be tackling the job very soon.
Old Jun 17, 2015 | 09:34 AM
  #70
jamestfl's Avatar
congrats on passing inspection. and for a great little adventure along the way...
