replacing wires
RE: replacing wires
Then you can definitely do it. It really is just a matter of removing hoses and unbolting. RAVE is actually the most efficient way to go about things. The only things that may not be obvious are:
- the purge valve hose: look under the rubber surround and push down on the grey tab and pull out. I had a little resistance with this one, but be careful not to break.
- the brake servo hose: push in on red ring and then just pull out. This one will come out super easy so if it doesn't stop and have another look.
also, the coolant fittings off the TB are plastic so be careful not to break those off when removing clamps.
