reset the emissions disco 2004
Old Nov 1, 2013 | 04:48 PM
ekimcorcho's Avatar
Default reset the emissions disco 2004
Hi, I have taken the disco to get the inspection but it did not pass the emissions (Catalyst not ready) and (Evap not ready). I drove the disco for a 100 miles prior to taking it in. Can someone tell me what I need to do to pass the inspection? All is well with everything else. The battery was disconnected at some point I suspect.
Ekim AKA MIke
Old Nov 2, 2013 | 11:55 AM
SuperSport's Avatar
I don't know the differences, but this is from RAVE:
Drive Cycle "D" is the one I've seen referenced the most on the web.
Code:
The following are the TestBook drive cycles:
Drive cycle A:
1 Switch on the ignition for 30 seconds.
2 Ensure engine coolant temperature is less than 60°C (140°F).
3 Start the engine and allow to idle for 2 minutes.
4 Connect TestBook and check for fault codes.
Drive cycle B:
1 Switch ignition on for 30 seconds.
4 Perform 2 light accelerations (0 to 35 mph (0 to 60 km/h) with light pedal pressure).
5 Perform 2 medium accelerations (0 to 45 mph (0 to 70 km/h) with moderate pedal pressure).
6 Perform 2 hard accelerations (0 to 55 mph (0 to 90 km/h) with heavy pedal pressure).
7 Allow engine to idle for 2 minutes.
8 Connect TestBook and with the engine still running, check for fault codes.
Drive cycle C:
7 Cruise at 60 mph (100 km/h) for 8 minutes.
8 Cruise at 50 mph (80 km/h) for 3 minutes.
9 Allow engine to idle for 3 minutes.
10 Connect TestBook and with the engine still running, check for fault codes
Drive cycle D:
2 Ensure engine coolant temperature is less than 35°C (95°F).
7 Cruise at 60 mph (100 km/h) for 5 minutes.
8 Cruise at 50 mph (80 km/h) for 5 minutes.
9 Cruise at 35 mph (60 km/h) for 5 minutes.
10 Allow engine to idle for 2 minutes.
11 Connect TestBook and check for fault codes.
Drive cycle E:
1 Ensure fuel tank is at least a quarter full.
2 Carry out Drive Cycle A.
3 Switch off ignition.
4 Leave vehicle undisturbed for 20 minutes.
5 Switch on ignition.
6 Connect TestBook and check for fault codes.
Old Nov 3, 2013 | 07:54 AM
Chrisinhouston's Avatar
I had my battery disconnected for several months last year when I was overseas and wasn't really thinking when I got home and reconnected it and took it in for an inspection the next day and failed! Different states have different rules reguarding pass or fail on the test but here in Texas if you are 1996 or older you can have 2 things show up as "not ready" and on later vehicles only 1. Usually your Catalyst will reset last of all.
Old Nov 3, 2013 | 08:29 AM
What are the exact fault code numbers, without them we can't really help you.
Also, there may be an actual problem and it will need to be repaired before you can clear the codes.
patrick in pa
Jul 15, 2009 06:22 PM
kfx4001442
Apr 14, 2008 11:08 PM
redr0ver02
Freelander
Jan 24, 2008 08:24 PM
ccredsox
May 29, 2007 06:56 AM
dualdiscos
Apr 10, 2007 12:25 PM
