rivets on secondary air pump
Old Mar 15, 2010 | 01:24 PM
pipjack's Avatar
Default rivets on secondary air pump
Hi everyone,
In going through secondary air system trying to rectify code 1451 (leakage detection module motor power stage error) I noticed that one of the rivets holding the secondary air injection pump was broken.
Does anyone know if it is a standard size rivet?
Could this have anything to do with the error code?
How do you remove air filter in SAI and clean or replace?
Thanks so much for the help!
Old Mar 15, 2010 | 02:29 PM
yloDiscoII's Avatar
https://landroverforums.com/forum/sh...ad.php?t=23245
Old Mar 15, 2010 | 04:25 PM
pipjack's Avatar
Thank you yloDiscoII. That thread is so helpful. Hey I might be relocating to Redmond soon, can you recommend a good LR mechanic?
Old Mar 15, 2010 | 05:27 PM
yloDiscoII's Avatar
No problem. I'll actually be attempting this filter change tonight myself.
I've had good experiences with Biggs Eastside. They are in Bellevue on Bel-Red Road. They are fair and know their stuff. I've heard stay away from LR Bellevue. Also heard good things about Lamorna Garage in Ballard. There's a shop that specializes in Series Rovers down in Olympia called British Pacific, haven't heard much good about them though.
If you end up in Redmond, let us know. There might be enough LR Forum-ers in the area that we could plan an outing!
Old Mar 16, 2010 | 12:42 PM
pipjack's Avatar
Will do. Thanks for the referral. I have heard of Biggs Eastside before and know exactly where that is.
Cheers, Maggie
Old Dec 22, 2010 | 10:14 AM
paytman's Avatar
Default 04 disco II SAI
Hi, my SAI started squeling really loud as if the bearings were going, and has now stopped. Should I replace entire unit (found used online for decent price) or take apart first to see if fan clogged/not turning?
Also have the 3 amigos, but feel that was after driving it into a very sandy ditch, most likely clogging or breaking a sensor...
Thanks.
Old Dec 24, 2010 | 04:43 PM
Rovin4life's Avatar
its supposed to go on first thing in the morning. when it doesn't come on thats a problem. thats when you get the check engine light.
schwaggy
Apr 13, 2025 07:02 PM
johnkbl
Sep 29, 2010 06:28 AM
charcoal grey
Mar 2, 2009 11:22 PM
jdelp
May 30, 2007 03:49 PM
akartis
Sep 25, 2006 01:31 PM
