Rocker Arm Bolts: Install dry or lubed?
Old Jun 12, 2019 | 03:43 PM
CT Rover's Avatar
Default Rocker Arm Bolts: Install dry or lubed?
Quick question to which I can't find the answer to: When installing the rocker arm bolts into the head are they installed and torqued dry or should they be lightly coated with engine oil? I have noticed there have been folks who have had them snap and I wonder if they were getting over torqued because they were lubed with oil?
Old Jun 12, 2019 | 05:31 PM
FlyingZebra34's Avatar
Those aren't tightened that much. 30-40lbs if I remember right. Or snug. I really don't even use a torque wrench for those anymore. I normally just send them in with whatever oil they came out with. Just don't hydraulic them.
Old Jun 12, 2019 | 06:13 PM
Extinct's Avatar
I like to lubricate them.
Old Jun 12, 2019 | 06:20 PM
I have ran a tap down them in the past than a quick blow out with compressed air. Bolts went in dry. This is not by any stretch what the manual says I’m sure
Old Jun 14, 2019 | 05:01 AM
The Deputy's Avatar
Normally, lightly lubed or sprayed with your choice of lubricant.
Brian.
Benjaminnesota
Sep 15, 2015 10:26 AM
NCguy
Sep 14, 2013 11:36 AM
ralford
Oct 17, 2012 08:41 AM
co556guy
Feb 4, 2009 08:01 PM
ajordan_0012000
Dec 13, 2008 09:04 PM
