Roof Bar Seals
I've been asked by my elderly neighbour , who owns a 2004 D2 and not very computer literate to put up a post on his behalf.
He has the G4 Roof Bars and has noticed the roof lining is wet, a closer inspection confirmed the roof bar gaskets are the issue.
Has called the local Stealers , who say the Roof Bar gaskets are obsolete and would not give out part numbers. Can anyone help auld Hamish with part numbers ?
There was also the possibility of using a sealant adhesive around the base of the bars and then setting the bars in place , what is the best adhesive to use for this and one that won't damage the paintwork , can anyone recommend sealant?
Been advised no TigerSeal as its hellish to remove if required to do so.
TIA
RizzleKicks
TIA
RizzleKicks
I used clear silicone, if use a soft plastic spatula you can lift the seal and get underneath - yes it is painful. Then you need to get around the roof bar where it meets the seal figure a couple of hours.
Also if there holes in the roof bar for cross rails get a bolt that fits and seal it really well
Mine has not leaked since I did that
@RizzleKicks Yup standard clear is all I used, you could use black if you can find it but it was easier to use clear.
Richard Gallant (04-07-2022)
The part number is M0338-001. They are the same size as the holes left behind from removing the roof bars. They fit right in but it is good to apply a small amount of silicone around the seal.
